TheBatteries
Administrator
- Oct 8, 2016
- 2,127
Data References:
http://www.repasebaterii.cz/files/img/datasheet/icr18650mf1.pdf
Pictures:
Brand: | LG |
Model: | LGAAMF11865 |
Capacity: | 2150mAh Rated |
Voltage: | 3.65V Nominal |
Charging: | 4.20V Maximum 1075mA Standard 2150mA Maximum |
Discharging: | 2.75V Cutoff 430mA Standard 10000mA Maximum |
Description: | Purple Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
