Monero Miner
hellhole
Just wondering what program every one is using to mine Monero?
I've been mining Etherium with the latest version of Claymore & decided to change to Monero for a bit & also used Claymores CryptoNote for Monero.
With the fork we just had i read my CryptoNote was no longer compatible though i haven't tested it, I just swapped back to Etherium until i find a new Monero client.
Any suggestions for Windows 10 Setup with AMD GPU's?
Hi,
Since the Monero algo update I've been using Xmr-stak for CPU and NVidia mining and its seems to work well with an easy setup. Just launch the exe and it guides you through it. I haven't tried it for AMD mining, but it says its supported. I downloaded it from GitHub.
github.com/fireice-uk/xmr-stak
DanH said:
Hi,
Thanks Dan ill check it out as i amdue for a Etherium payout tomorrow then ill swap to Monero.
