FesterJester
- Sep 22, 2018
- 5
To start, hello to everyone in the forums.
I have used a few answers from this forum over the years, but never joined until now.
So, I have recently started getting into re-purposing cells from old battery packs.
Recently, I got an K2 Energy LiFePO4 battery from a recycle center.
It was a 12V drop in replacement design.
It was kinda bulged on the sides, but it was holding a decent charge.
After a little research I found it was a bunch of small cells with anintegrated BMS.
I decided to carefully cut open the case and rescue what cells may be good.
(Performed in the middle of my lawn with a bystander ready . All went well!)
Unit was setup in what appeared to be 4 groups of 6 cells.
After getting the spot welded plates off the cells, I now have 24 LFP26650EV cells and a 12V BMS board.
I used a volt meter and found all the cells to be 3.17v - 3.36v.
I am in the process of charging each cell with a Nitecore Intellicharger NEW i2.
I will recheck the voltage a few days after charging each cell to look for voltage drops.
Question is:
How do I properly test each cell to see how "healthy" it is?
I have no problem building my own tester if needed, I have small circuits knowledge and experience.
Thanks in advance,
FJ
Question is:
Thanks in advance,
FJ
