Carl Martin
- May 29, 2017
- 1
Hi all
I was wondering if anyone could point me in the right direction on how to build a powerall 2 AC verison. From what I've read it's an all in one unit, has inverter and charger built in.
My current system consists of 12 solar panels all with power optimizersgenerating 3.4kw. connected to a solaredge se4000 inverter.
I like the idea of the powerwall 2 because I can install it without having to touch my current system.
I can't seem find anyone that has built a system that is stand alone like the powerwall 2. ie battery bank that has a lithiumion ACbattery charger and invertor which monitors your incoming supply which charges the batteries if your generatoring more than you are using and supplies you with AC when you need it. Also stops when your battery bank is to low.
manythanks
Carl
manythanks
Carl
