Mike Black
- Apr 11, 2018
- 3
I am selling a large quantity of Nissan Leaf Gen 1 Lithium Modules. Current price is $45/module which comes out to around 18 cents per watt hour!
These are second life Nissan modules which have been tested and graded. They are guaranteed to have at least 35Ah capacityat 50 amp discharge rate from 4.1V to 3.0V per cell (2 cells in series per module).
Here are some specifications:
Nominal Module Voltage: 7.6V (2S cells at 3.8V nominal)
Module Capacity: 35Ah (50A discharge rate from 4.1V to 3.0V per cell)
Module Energy: 266 Wh (Approximately)
Continuous current: 100A
Peak current: 250A
Dimensions: 12" X 9" X 1.5" (Approximately)
Weight: 9 lbs
I also have bus bars, BMS harnesses, contactors, and pack building supplies like brackets, etc.
Shipping is from $15 per module and up depending on locations. They are shipping from Norman, OK via UPS ground unless otherwise specified.
Message with questions and purchase requests. Thanks!
Peak current: 250A
Weight: 9 lbs
