After buying a few HW586 testers, I did some repeated testing on 1 cell with one of the HW586 devices and I was disappointed with how variable the resulting capacity numbers were.
I like the idea of the zb206 testers from how they look on paper, however I am wary of the same thing happening with them and they turn out to be no good.
I have been really keen to see Wolfs testing of these but I think it is still too cold in the shed where he is, so it has not happened yet.
PS Wolf, thank you for all the information you share with the community!
I now have over 800 cells extracted, so it is really time for me to start on testing.
Is anyone here using zb206 as their main tester?
With repeated testing of the same cell in a single zb206, how consistent are the capacity results and the IR results?
If you then test the same cell on different zb206 devices, do they give similar results to each other?
Should I use these?
Should I avoid these?
What is good?
What is bad?
Should I use these?
What is good?
What is bad?
