GeauxWandering
- May 7, 2018
- 5
Wattsup said:
Redpacket said:In the centre will be fine.
Just make sure the bolts still have enough reach with a blockmon & links, etc stacking up.
Note that at the left side of your pack, the cable/fuse, etc should connect to the top side ie the cell marked #10.
You have kept the nice parallel current flow design until the left side 3 cells!
PJon said:The parallel bus bars carry a lot less load than the series bus bars;
The series bus bars carry the full current draw.
The current the parallel bus bars carry reduces by 1/nth for each parallel link with n being the number of cells from the series link to the end parallel cell.
In your setup n=3 so the 1st parallel link carries 2/3 of the current draw and the 2nd 1/3.
If you put all the series links and end terminals in the centre it would give you n=2 in both directions so the parallel bus bars would carry 1/2 the current draw.
Same formula works for your Blockmons on the parallel bus bars, as they draw such a small current wherever is convenient is fine.
Jon said:Ideally the cables would move to the centre as well so the end bus bars are centre tapped as well.
Unless you have a fairly high current draw its pretty accademic, especially as your series and parallel bus bars look to be the same.
Your series bus bars are under much more load in any situation.
GeauxWandering said:PJon said:The parallel bus bars carry a lot less load than the series bus bars;
So if Im understanding you correctly. The mostideal setup would be to run the series straps right down the center? If I were to do that. Would the positive and negative cables stay where they are currently positioned? Or should those be moved to the center as well?
Thanks!
