I will test again tomorrow when I have more time. Tonights test was about a minute long using a very small 120v fan .35 amp. and 4 36volt batteries hooked in parallel. I would like at least 10 batteries hooked in parallel. About 40 AH 10s20p equivalent 10s2p x 10
But first impression of the 36v 3000 watt 120v inverter are positive. The user manual a bit thin nothing on 36v inverters nor 120v @60 hz
The over voltage LED was flickering @41.3v-41.2v input, maybe this is normal, the over voltage alarm didn't go off. Input range is 30v-45v, output was 122-121 volts.
later floyd
Did one more test with 2 batteries @36.5v Just to make sure it was a 36v inverter and not just one that the 36v checked. worked. So think I am good to go.
Later floyd
later floyd
Later floyd
