harrisonpatm
- Jan 5, 2022
- 401
Disclaimer: I am fully aware that unregulated charging a battery is a bad idea. This inquiry is for testing purposes only.
I'm playing around with some wind turbine setups, and I want to see if any of my configurations will charge my 14s Li-Ion bank. I can see that unloaded, my various small generators can easily surpass 50-60v. I would like to rectify their output (some are 3-phase, also playing with stepper motors and their 2ea 2-phase), and then connect their output to my battery to see their charge capabilities. I would monitor it and use a multimeter to measure current output. This should be okay, right? Normally what you would want to do is first connect the rectifier output to a buck converter or other voltage regulator, to make sure that the voltage output doesn't overcharge the battery; i've done this dozens of times. But for testing purposes, shouldn't my huge 10kwh battery easily act as a "load" for the tiny stepper motor and regulate its voltage for the purposes of testing its current capabilities?
Again, I know this is not standard practice. Just want to see if anybody has done this before, I want to check various turbine arrangements without having to order a 56v buck converter. Thanks!
