paraskevas
Member
- Joined
- Aug 8, 2017
- Messages
- 71
daromer said:
you will see it my friend .DarkRaven said:Hmm, what is that supposed to tell us? I don't see any fuses there. But yes, sure, it makes sense to fuse a pack. It isn't a substitute for cell fuses though.
you are very kind !.StefaanDeRidder said:from the looks of the photos, he is spotwelding the individual cells with nickel strip, and no fuse on cell level.
preparing a large block of 14SxxP, and only fusing the pack. (intending to add another six of those 14S blocks)
The ups (APC 3000W) is using 48V configuration, I think.
I think we will have to wait for.... heater, runners, fire, explosion...
Interesting to follow
best regards
Stefaan
best regards
Stefaan
hbpowerwall said:I think this could end badly for the community and isn't following best practice we are all striving for.
cristof said:
daromer said:Even though its not individually fused per cell basis thats something everyone will decide on. For instance its kind of hard or even impossible to find packs premade with LiIon that do have cell fuses (Lets not include Tesla).
So with that said I dont think its bad as such its just another way to do it and its all about the risks.
I have several packs here not fused on cell level (Though not on the powerwall that is LiIon) and still nothing blown up.
Have I said that one of the things I work with on daily basis is Risk analysis?
Geek said:It is true. I have never seen a laptop battery with more than 4 cells in parallel. Most manufactures suggest not - even with brand new cells. Personally I use a 6 cell battery bank.
One of the best things fuses can do for you is if you accidentally short a cell while assembling a pack (one user posted pictures somewhere around here having done exactly that) the fuses saved his cells and some severe burns. Probably more likely that the fuses will save you from user error than a rouge cell. The CID should do its job.
Fusing cells does not have an significant effect on build times. If anything that thin wire is so much easier to solder.
neurocis said:Geek said:It is true. I have never seen a laptop battery with more than 4 cells in parallel. Most manufactures suggest not - even with brand new cells. Personally I use a 6 cell battery bank.
Are you referring to "the incident" of Pete's? What a great learning experience and a testament to why things are done this way ...
the incident
Cheers!
