Sanyo UR18650P Cell Specifications
Brand:Sanyo
Model:UR18650P
Capacity:1700mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1700mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
340mA Standard
--- mA Maximum
Description:Red Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
https://www.master-instruments.com.au/fi...18650P.pdf
Pictures:
