SeRiusRod
Member
- Joined
- Jul 4, 2020
- Messages
- 56
I don't know how to title this question...
Say you have plenty of cells of 2200, and then a surplus of 1500-1900 ones up to be able to make two banks (14s100-110p). What would be more correct/safer to do?
The reason is, that I sorted things with energycells for the first bank, but I've also been contacted with someone relatively local, willing to send me laptop packson cheap. The only problem is the sample 300kgcells that I've checked so far, range this capacity.
What you will do with such different kind of cells?
- Mixing all the cells and make two banks of mixed cells.
- Build first one bank of 2200 (200Ah packs)and then build another bank with the rest. Without increasing the pack size to match. Is it possible to parallel different capacity banks?
- Build the first bank and increase the pack size of the second to match 200Ah. The cells on those packs will range from 1500 to 1900.
