1.21 Gigawatts
- Jan 22, 2021
- 7
I want to build a 10+kw powerwall & direct DC couple to a hybrid inverter.
Aside from being more efficient (i believe), the inverter can manage the direction of power as needed (export to home/battery/grid), & i'll be able to easily keep track of everything via the inverters cloud monitoring.
Solax inverters for example already offer this kind of solution, but using their battery.
I imagine the tricky part is getting the inverter to talk to my BMS.
Is it possible to connect a DIY battery to any hybrid inverter?
I haven't purchased the inverter or BMS yet. I'm hoping i can find a compatible solution.
I would like it to be 3 phase compatible. Minimum 10kw inverter (ideally 15kw)
I wonder if its possible to buy the same BMS used by inverter company. then they should definitely talk to each other. Propriatary code may still be a problem tho.
Cheers for the replies.
