A lot to unpack.
First, I'd suggest you step back and work on a test process - you should test each cell and put them in 100mah capacity groups by cell model number (e.g. Samsung or Sony or X).
Basic Test Process...
- Measure IR - if bad then toss.
- Charge, then Discharge (to get capacity and write it on the cell), then Charge and put the cell in a bucket or on a shelf or X by cell model and 100mah grouping. For example, group all the 2500mah cells in 1 bucket, the 2400mah cells in another, the 2300mah cells in another and so on.
- As the final Charge occurs and especially near the max charge, touch the cell with a finger and anything hot should be tossed. A little warm is OK.
Once you have enough cells for the entire battery - e.g. 7s12p would be 7 x 12 = 84cells + a few extra.....
- Wait at least 2 weeks (or up to 3 months) and check the voltage on each cell. Anything <4.10v is too much of a self-discharger and I'd toss it.
Next, assemble you're packs by evenly distributing the 84 cells among the 7 packs by type and 100mah grouping - so that each pack (pretty much) has the same mix of cells + same capacity. If 84 cells doesn't quite get you the capacity you want then do 7 x 13 or 7 x 15 etc.
Safety.... I've not found any issues with safety doing testing with brand name chargers.
Time... Yes, it can take weeks and months and years. I've processed ~15,000cells over 5+years. I did mine 12-16 cells (3-4 chargers) at a time but some folks setup a charging station with as many chargers as you can afford and do 20 or 40 or 60 or 100 cells at a time - there's no limit except $.
Here's a 12 cell setup using 3 x OPUSs that
@Wolf used early on and this is what I've used the whole time -
https://www.amazon.com/Battery-Charger-Tester-Analyzer-Adapter/dp/B09FRFPNXY/ref=sr_1_3 or on ebay -
https://www.ebay.com/itm/233191785125 or cheaper (rawer) alternative such as in this recent thread -
https://secondlifestorage.com/index.php?threads/new-tester-from-ali-any-good.12400/#post-90667
@Wolf upped his testing to a 64 cell charging setup using 4 x MegaCell Chargers -
https://www.megacellmonitor.com/MegaCellcharger
Whether you do 4 cells at a time or 64 cells at a time...... or do 18650 or LifePo4 XXXah cells/bricks or pouches or whole batteries or whatever....
***there's no other way to get good results than to test each cell or battery pack ***
If you don't test, then you will likely be unhappy with the results.
I don't say this to 'judge', just sharing what we've all learned the hard way
