On different aspect (please correct me if this is not appropriate) - I have been mulling over the long view and wondering how to track degradation in my cells as the 'years' go by.
Background:
My system is 48v@780ah / 40Kwh. I need 24kwh (60%) PV array storage in thebattery to make sure I don't loose any PV array power to 'battery full'. The batterybank isalittle over 5,000 18650 harvested cellsand its 'live' in that it charges/dischargesmostevery day.
The system automatically turns the inverter(load) on at 52v (3.71v/pack), will top out at amax charge of 56.4v (4.03v/pack - about 88% SOC), and inverter off is at47.5v (3.39v/pack - about 28% SOC). This is a max of 60% DOD in the 88% to 28% range of battery curve - but looks like it will average about 48% with bottom of 28%.
My question:
has been...how long will this battery bank continue to deliver 24kwhon those max PV array summer days. 5yrs? 10yrs? 20yrs?. So the key thing I'm interested in (as the years go by) is 'how much capacity' has been lost due to using the batteries. In theory, once I've lost over 40% of the battery's original capacity - I will no longer be able to get 24kwh out of - even if I charge to 4.2v and inverter off at 3.0v.
Solution:
To measure this, I've settled on tracking AH/volt discharge after the PV array input has gone to 0 for the day - e.g. to ensure I'm tracking 'pure discharge'. I'm using Batrium shunt AH and Batrium shunt battery voltage as the input data. So far (week's worth)theinitial numbers show an average of 67ah/volt. I should see thisdecrease as a loss of battery capability takes place over time - e.g. 67ah/volt should go down to 60ah/volt indicating a 10% drop.
I'm interesting in any comments on how to track battery degradation over timeon a live system (e.g. don't want to shutdown a pack or batteryto do discharge tests etc).
Thanks for letting me share
