Hi all i had a Broken Sony ij1001M Akku Pack with 128 Sony 26650 3000mah 25A Cells in so long so good.
I get Cheap K2 Energy Cells with 3800mah the white ones NEW and on the Datasheet they should work with 4C so around 12A
Ok more Space is allways welcome says may Brain
But now i am Confused here is why and i need a rly good Answer pls The Akku pack is a 16S8P Pack around 51.2 to 56.2 on loading max.
My Main problem is this Cells habe huge Energy Jumps on Charge and Discharge and i want to know what was my mistake or is it necessary to load them with 0.2C the first time?
Ok i was done had 4 Energy packs and all i needet to build the Battery as Sony want to a High Voltage System
So each pak Serial to the next so i get around 200V-230V
The Controller say all is ok all work well the Inverter say the Same and start Charging all is fine but when i check the Cell Voltages i get Confused.
All 3800 mah Cells had 3,3V Precharged i testet every one.
But on Charging the Cells jumps from 3,3V to 3,45V and that with around 1A with 3A it Jump to 3,55V ....... but then the BMS says Overload... the old bms go from 2,8V to maximum 3,55V
And the same on the Discharge it Break fast down to around 3V
The Sony Cells go on Charge from 3.3V to 3,42V BUT ON 16A!!!
I think this 3800 Cells are not 12A maybe 1C or is it possible i do a big mistake on build the 8 packs? I have no idea what was my mistake and i am rly frustratet now 128 Cells for the Trash and no i dont do it again................. Cut all out and Weld again all in........
