i need to change the battery in the music column (harman kardon onyx studio 1)
You can change the battery for one similar. It doesn't have to be the exact same model. The only thing you really want to make sure of that the "C" rating at least matches.
1C = Rated Capacity / 1000.
If your current battery is a 2000mAh cell, and has a rating of 1C, then it can discharge at 2A safely.
Then if you get a replacement, it needs to be able to be rated at 2A discharge minimum.
So with this example, if your replacement cell is a 3000mAh cell, and is rated at 0.5C, then this would be 1.5A. It doesn't meet the requirements. It would have to be at least 0.65C, or 1.9A, to be compatible.
The reason is because if your device regularly pulls power close to the rated amps, then you will 1) drain the battery faster if it's underrated, and 2) will cause the cell to overheat during usage. Both of these you want to avoid.
If you get a cell replacement that is higher in capacity, and has equal C rating, or higher, then you will add longevity to the life, and run time of that battery.
If you are in doubt, don't hesitate to ask here so we can verify your numbers
