IronSky
- Jun 12, 2017
- 52
Gazelle E-Bike Battery
Behind the connections (which can be unscrewed) are lids of plastic.
Unfortunately the lids are glued to the front and the end.
Even with a sharp knife you can not loosen the glue.
The only possibility is the battery on the sides cut open.
I use a small circular saw, the cutting depth is approx. 3 mm.
If one cuts at the places as seen in the pictures, one does not damage the batteries.
Here are a few pictures where you can see how much work such a small battery can make
At the end you will find 40 cells with about 2200mAh
Iron
p.s.: I hope you can read my English so much :angel:
Iron
