AndrewBrown
- May 26, 2020
- 25
Hi Folks!
Greetings, I am planning to build portable power station for off grid camping. I drew the schematic and wanna ask you advice regarding attached scheme and connectivity of the components.
1. Is the scheme correct?
2. Where can I find option how to connect all wires together? Wich way is better and durable? (crimp connectors, soldering, or Wago pluggable connectors)
3. Is there are any other options for connection?
4. I'm planning that load shouldn't exceed 20A .
5. Where should I allocate the fuse?
6. My main switch can hold 5A max, so I assume the I should use relay. How connect main switch with 5 legs to the relay which has 4 legs.
Thanks in advance for any help.
