@Gesbert please use
Google Translate if you don't know english.
Ecrivez en anglais s'il vous plait; vous pouvez également utiliser Google Translate si vous préférez.
Translates to: "
Creation of a 6S1P pack.
The first battery given by “Cell Savior Pack Builder”: 1 – 2137ma must be connected to + or -2....6 – 2135ma must be connected to + or -Maybe that doesn't matter?
Thank you for your answers
I suppose you're using a site called Cell Savior Pack Builder to create a 6S1P battery. You must connect them, one after the other ("in series"), negative with the positive of the following cell, until you reach the last cell. When you connect them they should all be at similar voltages.
In series the resulting voltage will be the sum of the single voltages.
IMPORTANT: use safety measures when using lithium cells. Use a mask, eyes, body and hands protection. Do the job in a safe environment. These batteries can cause damage, fires, explosions, intoxication, burns.
IMPORTANT : prenez des mesures de sécurité lors de l'utilisation de piles au lithium. Utiliser un masque, une protection pour les yeux, le corps et les mains. Effectuez le travail dans un environnement sécuritaire. Ces batteries peuvent provoquer des dégâts, incendies, explosions, intoxications, brûlures.
