Greentec Auto
- May 1, 2020
- 7
Valence U27-12XP Lithium Ion Battery Module | Greentec Auto
60Ah Li-ion 12V battery accepts high rates of charge and captures several times more energy from regenerative braking for improved fuel economy and reduced emissions
The easiest thing would be to get the module to any of our facilities, and we would take care of the shipping.
We are selling the modules in bulk orders only.
Minimum purchase quantity will be 8 modules. The reason behind this is for easier recovery for recycling.
Available upon request are small busbar segments to connect the modules in series. Also available are aluminum stands that the modules were originally housed in.
BMS is hooked up and in standby mode. Software is available to look at Individual Voltage Cells, Temperature, SoC, Charge Cycles, Warnings, Faults, and Highest Current, Voltage, and Temperature History.
BMS will automatically balance the cells within one module during the top of the charge.
Will not balance between modules when hooked up in series, only in parallel.
Look at QNBBM 12V balancer for solution.
QNBBM Battery Equalizer With Light | Greentec Auto
QNBBM balancers work by taking energy from the highest charged battery and using it to recharge the lowest charge battery
Capacity @ C/5, 25 °C (typical) 138 Ah (New)
Energy 1.76 kWh (New)
Discharge Cont./Peak (30 sec) 150 A / 300 A
Discharge Cutoff Voltage 10 V
Recommended Charge Voltage 14.6 V
Charge Float Voltage Range 13.8 - 14.6 V
Recommended Charge CCCV ≤ 72 A to 14.6 V
Discharge Temperature -10 °C to 50 °C
Charge Temperature 0 °C to 45 °C
Self Discharge @ 25 °C < 2% per month
Terminal Hardware M8 x 1.25
Terminal Torque 25 Nm 222 in-lbs
Plastic Case Flame Retardant
IP Rating IP56
Features
• >4000 cycles at 80% DOD
• Create systems 12 - 1000 V
• Series and/or parallel operation
• Automatic cell monitoring & balancing
• Temperature monitoring of cells
• Rugged mechanical design
• Thread locking feature
• Footprint of Group 27 lead acid case
• Maintenance-free
• No hydrogen generation or gassing
Height: (excluding bolts) 225 mm 8.86”
Width: 172 mm 6.77”
Length: 306 mm 12.0”
Weight: 19.2 ± 0.1 kg 42.2 lbs
Cell Configuration: 4IFpR27/66-44
Shipping: Free - the cost of shipping to you is included with your purchase. Freight to business address or pick up from a local freight hub only.
