I use axial glass fuses for fusing individual cells in my various projects. Well, the larger ones anyway. I end up with a lot of leftover leads that I clip off the fuses which I collect in a jar. Maybe that's weird, but I don't like to throw things away if they might be useful later. This time, they made great extensions for some old components that a friend of mine had stashed away and recently gifted to me.
This allowed me to put them in a little component tester I have. Turns out the big ones are capacitors, and the little one is a resistor. The bands would probably have told me that also, but I don't know how to read them. I didn't even know capacitors had bands.
(Usually the tester also gives me an ESR value, but in this case it didn't.)
This is a pretty neat gadget that identifies capacitors, diodes, resistors, inductors, and transistors. Doesn't recognise everything, but it sure is better than I am!
Anyway, you can see it's powered by a 9V battery. Well, I have several boxes of components that my friend gave me. Most of them are quite vintage looking. Over an afternoon of testing and sorting, I still have a long ways to go, and the 9V battery was getting weak. The simple thing to do would have been to track down a fresh 9V. But why do that when I can 18650 it!?
I had to make new holes in the sides of the cell holder for the wires, as the holder itself just barely fits inside the box. Oh yeah, I also decided that this time I would like the cell permanently inside the box and to charge it without taking it out. Unlike the pocket oscilloscope. Anyway, first thing to do was to remove the 9V connector.
I drilled the holes with a cordless Dremel that I haven't quite finished 18650-ing yet. I have a number of old 12V tools, and I want to make an 18650 battery that can run all of them. But it's still a half-baked idea, and I don't know exactly how I want to proceed. Maybe it will end up in a box I clip to my belt or something. Anyway, yeah, the cell holder with wires coming out the sides now:
Those leftover fuse leads I have saved up: also great for sticking a Voltage protected TP4056 board to a booster board. These little boosters are great, and I've now used them all up. I'll need to order more.
With the cell holder soldered to the TP4056 board, I can adjust the output on the booster board to just over 9V. I'm not sure what the Voltage range of this gadget is, but it's able to run on 8.8V, though the screen starts to flicker a bit. The oscilloscope sure didn't run on that little, but I think it takes more power than this tester does.
(The components at the top of the picture aren't part of the tester. They're part of that stash waiting to be identified.)
It took quite a while, but I finally got a hole filed in the acrylic to allow the USB port on the TP4056 board to stick out. Acrylic is not a forgiving plastic like polycarbonate. It is brittle, and likes to crack if you try to drill or cut it. I also had to peel off the protective coatings as the dust was just collecting between the coating and the plastic. Normally I'd leave it on except for the top. Just my personal preference.
I got the boards hot glued to the box, and soldered wires from the booster output to the 9V input on the tester board. It all fits with room to spare. (So far...)
Here it is testing a 3-pin IC of some sort. During testing, it tells you the status of the battery. In this case, 9.15V. So success!
Turns out I have an N-E-MOS. Whatever that is, LOL. Looks like a transistor with a couple diodes from the little graphic. Pretty neat, eh?
It doesn't test stuff with 4 pins or more. But that's ok. Here is the tester, now getting it's cell charged. Works great.
And since it's transparent, it's easy to see the LEDs on the charger.
So one thing I forgot: I've mentioned before that I like to charge my cells at 500mA instead of the standard 1A. Especially since this is a generic Sanyo cell and I don't know its specs. I've been adding little 10K potentiometers set to 2,500 Ohms. I did this after the fact, and it turns out the potentiometer sits right in the way of the support spacer under the board. That's going to drive me nuts until I get it repositioned, LOL.
I should probably buy a bunch of 2.5k resistors. They take up a lot less room.
