dulifa
- Mar 22, 2021
- 4
Today I came across this one's removed from a Toshiba 96Kwh power pack, they are red with red ring also and they are marked Sanyo R1112, i search the forum but I can't find it, any help?
lol 96kwh did you harvest it from Tesla Model S P100D?Today I came across this one's removed from a Toshiba 96Kwh power pack, they are red with red ring also and they are marked Sanyo R1112, i search the forum but I can't find it, any help?
i think you search for this :Today I came across this one's removed from a Toshiba 96Kwh power pack, they are red with red ring also and they are marked Sanyo R1112, i search the forum but I can't find it, any help?
Model | ZNB 3.7v li-ion Battery |
Nominal Voltage | 3.7V |
Nominal Capacity | 2200mAh |
Discharge Cut-off Voltage | 2.75V |
Charge Voltage | 4.2V |
Stardard Charge | Constand charge current 0.2C,Constant voltage 4.2V,0.01C cut off |
Standard Discharge | Constand current 0.2C,end voltage 3V |
Fast Charge | Constand charge current 1C,Constant voltage 4.2V,0.01C cut off |
Max. Continual Charge Current | 1C |
Max. Continual Discharge Current | 2C |
Storage Temperature | -20~60°C |
Cycle Life | 500times |
Certificate | CE,UL,ROHS,CB, UN38.3, MSDS |
Here's a datasheet to add for that submission: http://queenbattery.com.cn/index.php?controller=attachment&id_attachment=98From a Black & Decker 20 volt Max 1.5AH battery pack dated March of 2017, I understand that these pictures are not ones that you would like to use for a thumbnail however tearing a cell out of my battery pack just to get a cleaner picture and then have the spot weld it back in was not anything I was looking to do but I wanted to get the cell at least seen
Found 20 of these inside Ryobi 40v battery pack.Hi all,
I have some new LG cells (well they are from around 2013-2016 per the pcb they came out of)
They are out of a drillbattery pack.
LGABHE21865
P322K176A8
If i had to pick a color they are a pinkish salmon red.
I cant seem to find any specs on these, i have 5 of the battery packs and they are all the same cells
